SS-V: 6010 Simply Supported Thin Square Plate - Periodic Forced Vibration Response
Test No. VD02 View transient response of a simply supported square plate subjected to periodic forced vibration .
Definition
- Excitation frequency.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
- Properties
- Value
- Modulus of Elasticity
- 2.e+11 Pa
- Poisson's Ratio
- 0.3
- Density
- 8.e+3 kg/m3
Results
- to the top surface of the plate, and
- to the bottom surface of the plate
Deflection Y, mm | Surface Stress, MPa | |
-2.886 | 2.062 | SimSolid, solid model |
-2.863 | 2.018 | Reference, thin plate model |
